gtranquilla
RadioActive
Originally I wondered why the DJI S800 motor arms were tilted upward at the end of each motor arm.
A closer look at several other newer Hex and Octoframe designs shows they are now doing the same.
Some are 3 degrees and some are up to 10 degrees dihedral. 10 degrees seems a bit excessive and might lead to less total airtime due to lifting efficiency loss.
These manufacturers are claiming the dihedral increases hovering stability but also helps to eliminate random yaw when travelling forward.
Since my custom 800 mm Hex w/o dihedral tends to yaw into the wind when flying forward, it seems this concept would help to correct the problem.
Anyone care to comment further?
