I have a gothelirc.com Brushless Nex5 gimbal, and need to connect it to my landing gear which has droidworx 8mm (outer diameter) sized tubing.
What sort of adapter can I buy to connect to this tubing? Better yet something with quick connect?
Some pictures to give you an idea of what I'm working with. (the gimbal is held on with zipties in these photos)
The bottom of the hexa with the top of the landing gear. You can see they use droidworx sized tubing which I have attached zipties too.
Tarot Hexacopter
Jakub Quadframe.com 310 mm Legs.
http://quadframe.com/collections/legs/products/310mm-clearance-landing-legs
Gotheli Brushless Gimbal
http://gothelirc.com/shopdisplayproducts.asp?id=203&cat=Brushless+Gimbal
I'm looking for an droidworx adapter to connect to those tubes so I can incorporate a vibration solution and then connect the gimbal to that. The tubing itself is 8mm.
I know this isn't all droidworx gear so I really appreciate anyone helping out. I'm at a stand still.
Dane
Tarot Hexacopter
Dane
