llamatrails
I am converting a working quad to use a MK FC v2.1ME with an AbuseMark i2c to PWM converter. No Navi-Ctrl, GPS, or MK3Mag boards.
The quad has been flying fine with a HoverflyPro FC.
KDA 20-22L motors
Turnigy Plush 30A ESC
Precision I2C to PWM Converter for Standard ESC [ST] w/ 2011/04/21 firmware installed yesterday, no problems with the procedure
3S 4000mAh LiPo
The MK is running freshly loaded 0.84a firmware, configured for a Quad-X Beginner. All settings are default, other than disabling the GPS and enabling the Altitude Control. The i2c board is wired with the molex connector on the FC, I cut the molex cable and crimped in a 3pin servo connector to connect to the i2c board.
The problem is that the motors do not all spin at the same speed at idle, when I enable/start the motors. I can see #3 is spinning slower, and #2 may not even start. If I increase the throttle, they will all spin up, but #2 will stop before I reach liftoff. Obviously, I have not actually tried to lift off.
I originally had the ESC timing at low, and changed it to medium to match what I have found in the announcement/support thread for the i2c board. The problem still exists. There is also some chirping of the ESCs.
On the MK when in MKTools, I can run the motor tests and all 4 will run. I can advance the throttle on each individually, none cut out as the throttle is increased.
I did notice that the LCD in MKTools only shows 1 BL-Ctrl instead of 4. Is this correct?
Anyone have any insight as to why the motors aren't spinning up at the same time/speed and staying on?
KDA 20-22L motors
3S 4000mAh LiPo
