Wow they are cheap!!!!Around here APC seems to be the prop of choice. Durable, cheap, and much better than GWS. They aren't as nice as carbon but much cheaper and not so brittle
Whats a good prop that is reliable and is not too expensive for a quad, hex and oct build. 13'' 14'' and 15'' props.
Are the rctimer blades good?
I have used the plastic props with carbon fiber fill and they just didn't give me the comfort level I needed, they came apart. I went to RCtimer and bought some carbon fiber propellers and they are great. I had a lean over and they hit the soft ground (lawn, grass) and didn't come apart. They are very stiff and seem to work well. They are not cheap, but what is my aircraft and camera worth? I fly the 13.4 props. Good luck!
I have also been trying the RC Timer props recently, quite good and reasonably priced.
ok coolI'm betting a bit of money they are. I have complete confidence in them. Only time will tell.
Im just confused on one thingIf your motor shanks, the smooth part of the shafts, are greater than 3 cm, I don't think you can use. They do have some with a thicker hub if necessary. As to the lift I use a low pitch to help keep the vibration low.
