gtranquilla
RadioActive
							And so simple to adapt to MR design..............
It's really no different than a cp heli. The coax design would just add unnecessary complexity, and the pusher fan on the back is pointless on an rc aircraft. How fast do you want to be able to fly?
From what I understand so far.... the Quad, Hex and Octocopters have more stability that do the large rotor helicopters.... in the sense that you can park them at a 3D spot in the air and focus your attention on other things such as camera gimbal control.... (although the hover can sometimes drift up and down at least the 2D GPS position remains solid)....... And from what I understand from the above video.... the Sikorsky X2 has superior stability and handling over the conventional CP chopper........ A Video producer indicated to me that my 800mm Hex seemed a bit slow for forward flight for his plans.... although I did not fly it in manual.....so the Sikorsky X2 pusher prop does the job without the main rotors moving off the horizontal plane.... .
If I had the time and money I would only fly CP helis, the simplicity of MR's is what draws me to them. A coax-ax with a pusher prop doesn't hold any advantage for UAV AP that I can tell.
CP heli's can autorotate. 450 Size are the smallest I've tried and it is quite a handful on that small of one. 600 size and up auto very well. Ap ships are a different story because of the added disc loading and slower head speed , but they can still do autos.
In any case I am a firm believer that coax can be as efficient as single props when done correctly and possibly more efficient as was indicated by Howard Hughes aeronautical engineers back in the 40's....... and this new Sikorsky X2 claims the same....
the point of quad/hex/octo/whatever multirotors is the fact they are based on simple motors and propellors , survive the odd impact and cheap to repair combined to a heli
Most people don't bother with them though because a/ they are harder to fly and b/ they are harder to set up correctly.......discuss
