Tarot Carbon Fiber Props
PeteDee
Mr take no prisoners!
I suspect they will be similar quality to the RC Timer props, and they are pretty good for the price.
LeeT
Wannabe AP Dude
These arrived very quickly. They are definetly nowhere close to being balanced. One blade was very much heavier than the other on all four props. Usually when I balance props I use 220 grit and then smooth it out with 400. I had to use 100 grit to remove enough material to get the balance even close and then did my smoothing routine.
That said, I put them on, and they fly fine. Completely different sound than the Gemfan carbon filled nylon props. I had to do an emergency landing, the quad was moving forward about half speed and 4' off the deck, when I hit throttle hold. No damage to the props that I could see. I flew it again, low and slow, and the props are fine.
LeeT
Wannabe AP Dude
Other than being a ***** to balance, I like the props. Super stiff, and very tough. I bought more so that should answer the question.
