UgashikBob
During one of the first attempts to hover my F550 I would get the first and second level battery alarm and unit would descend. After shutting off the battery alarm in assistant it worked ok for a few very short flights and now it will start descending because the telemetry data shows the battery droping to 6.6-6.7 volts and then going to 11.3 after landing.  When I recharge the charger starts at 11.9 and goes to 12.60 and only shows 820mah of the 5000 used. The battery is a Sky Lipo 5000mah 30c. It was new with the unit and has had most of it use doing calibrations and maybe 45 minutes total flight time. Anything else I should look at before replacing the battery?
