NAZA - Return to Home
medivac
I have a question about the return to home feature on my F550 with a a NAZA. While flying the other day I tried testing it out. When I flipped my switch it started to descend. I returned the switch to normal and retried this several times with the same result. I then landed it where I took off from, kept the blades running and hit the switch. It took a few seconds and then took off in the air..... I'm guessing the 20m or so. Problem now was that it took a really long time to come down.....give or take 5 mins or so. It came down down to about 2 or 3 feet and just hovered. It actually wouldn't land until my low voltage cut-off shut it down.
The feature had worked prior to the software update. I have the return to home selected in the software. I have a V1 and upgraded the firmware. What is going on? As well is it normal once it is returning to not have ANY control over the craft....even after flipping the switch back to normal? Any feedback would be greatly appreciated.
medivac
For sure. I just didn't see that anyone else had a similar problem. I will try and revert to the previous version....grr
