Quick vid after adding S800 Anti Vibration kit
hazardpro
Hi guys
This is a video we did the other day after adding the the anti vibration kit to our S800. It now flies a lot better (back to how it was when it was light).
Video is far from perfect I know but it was my first time behind the camera as i normally fly.
Also need to make some adjustments to my Aurora 9 to make the sticks a bit 'softer'.
Anyway hope you like.
[video=youtube_share;3koNJqoYeu0]http://youtu.be/3koNJqoYeu0&vq=large[/video]
mitsaras
Looks pretty good to me!!:encouragement:
btw, do you get any flicker with your NEX? We use the 16mm on the 5R and we get a very annoying flicker on some shots that I can't quite pin down...
Ni job HazardPro! My vibration kit arrives next week. Can't wait to install it and see how it helps my S800.
Mitsaras, I get a flicker also. I'm using the 16mm on the 5R with the DJI VTx and I get flicker once in a while. I just figured it was my Tx/Rx connection, not the camera.
mitsaras
Unfortunately we get flicker on the recorded video... it usually happens when the aperture is stopped down beyond f11 - it might be vibration affecting the aperture blades? I need to get a varioND filter to keep the aperture @ f8, where the lens is sharpest...
blushoes
hi mitsaras
i get flicker too. i do think its the vibrations as i noticed that the flicker only starts when in the air. as long as craft is on the ground and even though motors are running, i dont get flicker. only upon lift off do i get it.
am ordering an anti vibration kit too, to see if it removes it.
You can try and place a small piece of tape on the top of the lense to act as a sun shade and see if the flicker goes away.
blushoes
got my s800 anti vibration kit
it has reduced flicker significantly, but still the odd glitch here and there.
then i tried using dji's suggestion of having manual exposure and shutter speed (it was sunny day, my f number was all the way up... shutter set to 1/40 )
that got rid of the flickers
hi mitsaras
