Benjamin Rowland
EDIT: FIGURED IT OUT. TWO ESCs PLUGGED INTO WRONG CONNECTOR. YELLOW AND ORANGE LOOK PRETTY SIMILAR ON JUNK LAPTOP. :strawberry:
I'm trying to get a HoverFly Sport board working on IrisAerial's FNF frame and have run into a problem I can't diagnose.
While in the setup utility looking at the artificial horizon, I tilt the aircraft, and the horizon tilts as it should then snaps back to level even though the aircraft is still tilted.
I'm uploading a video of this now.
Why does it matter? Because the HF Sport thinks it's level no matter how it is tilted which means flipping on takeoff. It registers the tilt for a moment, but then thinks it's level again, when it definitely isn't level.
Suggestions?
I'm using the latest firmware. I've tried flashing it a few times. Same result.
Suggestions?
