Hi, all,
just crashed my Xaircraft Hex rather badly after losing control on an apparent flyaway. The stock Xaircraft GPS antenna was lost, and replacing it will cost about half what an entire Naza-M/GPS will cost, so it may be a good idea to buy a Naza, which seems to be more popular/reliable.
On th Xaircraft system, there was a "constant heading" setup that was very confusing to me: it would apparently make everything relative to a fixed compass direction. So if you happened to start out pointing due North, then yawed 90 degrees right, pitching forward would actually make it bank left, and head north. It was very disorienting.
I found myself wishing that it would instead act like I was the center of the universe, so that pitching back would always bring it back toward me, no matter what the orientation of the copter was. So in researching the Naza-M, I find this confusing bit of verbiage:
"In home lock flying, the forward direction is the same as the direction from home point to multi-rotor."
its pretty hard to tell from the words and diagrams, but this SEEMS to be describing what I am after. Is that true? So no matter what direction it is from me or where the nose is pointed, pitching forward moves the copter away from me, and backward brings it back?
Thanks!
Thanks!
