Webheadfred
Air Traffic Controller
Well... Maybe it's a build thing. I just like building.
After some disappointing performance with the big X8 I made some observations and I'm making a change. While watching my x8 fly, she flew beautifully on manual but I could never get the GPS to hold worth a darn on PH. So I watched it carefully as I was bringing her in and noticed quite a bit of flex in the arms as she hovered at eye level. I also noticed that she was a bit front heavy from the camera gimbal position so, I assumed the front motors were working a little harder than the back to maintain level. My wiring harness was a quagmire as I didn't give it too much thought as far as position as long as it was 'in there' and electrically sound. I fit all 8 40a Turnigy Plush ESC's in the main body of my Rusty's frame along with the wiring harness so I imagine there was quite a bit of magnetic field wreaking havoc with the magnetometer, even though I had an external one. So here goes....
I rebuilt it into a Hex. Same Avroto 2814 motors. Instead of 11x47 props, I'm planing on using 12x38's. I built it from the wiring harness up, being careful for symmetry in the harness and twisting the positive and negative wires. I moved the ESC's to the more reasonable length arms on specific mounts to keep them firmly in place. On the X8, I was 41" MTM and on this hex, I'll be 31" MTM. It's perfectly balances front to back and side to side with the camera gimbal and camera on. I'm planning on placing the battery on top for ease of access and more centered CG. I'm using stiffer carbon fiber arms and the entire build is much stiffer than the previous X8. I'm thinking that by going to a flat hex versus an x8, I'll regain about 15% efficiency than a coaxial configuration, I'll be lighter by two motors and I'll draw less current from the battery. I should get a little more flight time (hopefully).
It should be finished and ready to fly this afternoon or tomorrow afternoon (if it stops snowing) and I have a question. With the HFP and GPS, will the flight characteristics be similar as far as hovering and maneuvering versus the X8? I'm still a novice with this RC stuff and if anyone has any suggestions, I'd appreciate it... Thanks.
