peterorpete
Hi I'm about to buy my first quadcopter and have decided that the dji 450 is for me. I wanted to keep the whole setup around the £500 mark. So for that reason i will forgo the naza gps component until a later date. From reading, most advise that a 8 channel transmitter is best if you intend to use things like gimbals and gps in future.
Any way I found this deal:
http://www.swiftrc.co.uk/dji-innovations-flame-wheel-f450-quadcopter-combo-packages-262-c.asp
which seems surprisingly cheaper than anything i have found, could anyone in the know let me know if this is a good deal and why it is cheaper than the others?
Also i found this from http://quadcopters.co.uk/ who wrote:
With the DX8 you can add telemetery modules simply by plug and play and have voltage , temperature, height and much more. Also with the spektrum there is onboard alarms that can be set up and with the ergonomic design and slick backlight system makes this a clear winner in the radio field , also is compatible with the older dsm receivers .
This unfortunately is not possible with the Futaba T8J with R2008SB receivers. If you would prefer to have a RTF with a Fubata radio we can of course do this but we do recommend the Spektrum.
Do you think the fubata radio T8J is not suitable to work with the dii 450? And should i instead invest in the spektrum instead.
Thanks for your help
