If you are using the HoverflyGPS....AND....you want to use magnetic yaw hold then tick the box.
Normally the yaw is controlled based on the gyroscope on the HoverflyPro. If you are using the HoverflyGPS then you have the added ability to use the magnetometer to hold the yaw in position.
