paktazh:
One question. You do have the GPS fitted correct?
I'm fairly new to multirotors and find IOC a great selling point for new pilots. When flying line of sight(LOS), it's such a confidence builder to know that if you do get dis-oriented, flipping a switch can bring the MR back to you or to a position you can re-orient yourself to it.
The HOME LOCK feature is the one referred to but needs a GPS and good satellite lock so NAZA knows where "home" is. I've never used COURSE LOCK, and only barely understand the function.
I fly FPV now, so IOC isn't something I use, although it is handy even with FPV flying say if your video drops out for some reason.
One other thing I would like to point out and that's the difference between IOC HOME LOCK and a full blown NAZA switched failsafe. The NAZA return to home (RTH) has some great features but you need to remember that those steps NAZA takes to come home take time. Once triggered your MR will stop and hover for a few seconds, possibly climb if its altitude is less than 20m above where you took off from, then fly home, stop again in a hover and very slowly descend to a landing. What happens when you run out of battery during all this?
I once timed a RTH from approximately 400m away and it took my MR 35 seconds to come overhead. I did not time it to landing from the 20m height. But knowing what I now know about IOC, I could have gone to IOC HOME LOCK, pulled the stick back and had the MR overhead probably in half the time. Of course I knew I would be above obstacles coming back even if I had used IOC.
You also still have throttle control during IOC, which you don't have in failsafe RTH, to climb if necessary. Just something to keep in mind.
Ron
