Hey Guys
I know this is an older thread, but I need some guidance if anyone is in here.
I have an AV2 Mini converter to connect my GH3 to my FPV TX and it works just fine.
The problem I have is finding a compatible
HDMI to Mini HDMI cable.
I need a 90 connecter on the Mini side so that the cable won't interfere with my gimbal frame, and I need it to be super thin or a ribbon cable so that it won't weigh down or tug at the gimbal.
I purchased one on eBay and found that these aren't all wired the same.  The one that I purchased claims to be for FPV, etc, etc  but does not work with the GH3 (which uses a standard HDMI configuration).
Upon further investigation I learned that the pin-outs are totally different from the cables that work with the GH3 (again standard cables).
My dilema, how do I know which cables available are going to work??  There is little help in just going by the descriptions, so how do you determine which cable will work without purchasing a dozen or so and hoping to find one that works?
Is there a term or protocol I should use or look for?
Anyway, I would much appreciate any help you could offer
Anthony
