Introducing the Eachine E58 (a Mavic Pro clone)
Following the success of Visuo, Eachine also announced their own Mavic Pro clone. The E58 follows similar foldable design as the much expensive DJI drone. Of course, the specifications are much poorer and comes with less reliable brushed motors instead of brush-less ones.
Thanks to the barometric air-pressure sensor, the Eachine E58 quadcopter is capable to autonomously maintain its flight altitude at the desired level. Headless mode is another feature that makes flight more easy.
Eachine advertises the E58 drone in two variants. One with 0.3Mp camera and one with HD 720P camera. Both versions are powered by the same type of 500 mAh Li-Po battery.
Additional to the included remote controller, the Eachine E58 can be also controlled through smartphone APP. Kids will love to control the aircraft movements through their phone Gyro sensor.
Eachine E58 features and specs
  • Mavic alike foldable design;
  • Easy to replace brushed motors;
  • Barometric altitude hold;
  • Headless flight;
  • One key return to home;
  • Emergency stop button;
  • One key Take off / Landing;
  • 3-levels of speed rates;
  • Optional 720P or 0.3MP camera;
  • WiFi real-time image transmission;
  • Smartphone APP control (Virtual sticks or Gyro sensor);
  • About 7~9 minutes of play time;
  • Up to 100 meters control range.
During night flights you will be guided by 4 LED lights, one under each arm. The Eachine E58 also has two additional frontal lights which helps newbies to track the orientation of the aircraft.
Included in Eachine E58 fly more combo package
  • Remote controller with phone holder;
  • 3 pieces of flight batteries (500 mAh);
  • USB battery charger;
  • 1 pair of spare propellers (4 x blades);
  • One set of propeller protectors;
  • Screwdriver and spare screws;
  • User manual
Source: FirstQuadcopter
Leave a Reply
