Welcome To RISE – Race Harder!  Introducing the RXD250 FPV Racer From Hobbico
Race and train at the absolute edge
Stripped down, light, and made from high-impact foam and carbon fiber, the RISE RXD250 lets you cut in close to every obstacle and compete in the craziest and scariest courses. Go ahead and push it. The RXD250 is designed to withstand a crash—and to go fast.
Unstoppable
The RXD series stands for RISE Extreme Durability. Carefully crafted to be supremely rugged, every RXD250 frame is constructed using a premium foam/carbon composite. Pre-built and Receiver ready—just add your battery, receiver, and fly!
Pre-programmed CC3D
Pre-programmed flight controller, perfect out of the box.
Vivid LEDs
Vivid LEDs make it easy to see the RXD250 in low-light flight.
Camera mount
Includes a camera mount optimized for FPV racing. Add a compatible camera for exciting First Person View action!
Includes:
  • Pre-built RXD250
  • Pre-programmed CC3D controller with LibrePilot
  • CC3D wire harness
  • (4) 5×4” props
Specifications:
  • RISE0250
  • Diagonal Size: 9.8 in (250 mm)
  • Weight: 10.6 oz (300g) less battery and FPV
Requires:
  • 5-Channel radio system
  • 3S 1500-1800mAh LiPo battery
  • LiPo balancing charger
Leave a Reply
