The Phantom 4 Won’t Disappoint Will It?  What Do You Think About DJI’s New Drone?
The DJI Phantom 4 flying camera (as DJI refers to it) packs in a lot of new features.  And so the Phantom evolution continues– read about it here  |  Talk about it here
What do you think?  Did DJI hit the target or did they miss on a few things you were hoping to see included in the Phantom 4?  Have you put your order in yet?  Or does the 4’s features have you shopping around?
PHANTOM COMPARISON
BUY PHANTOM 4
BUY PHANTOM 3 ADVANCED
BUY PHANTOM 3 PROFESSIONAL
BUY PHANTOM 3 STANDARD
Created For High-level aerial photography and cinematography High-level aerial photography and cinematography Beginners & First-time pilots
In The Box 1. Phantom 4 Aircraft
2. Phantom 4 Remote Controller
3. 3-Axis Camera Stabilization Gimbal
4. Built-in Camera Captures 4K video & 12.4M Photos
5. DJI Lightbridge Video Downlink, 5km range
6. 4S 15.2V 5350mAh Intelligent Flight Battery
1. Phantom 3 Professional or Advanced Aircraft
2. Phantom 3 Pro./Adv. Remote Controller
4. Built-in Camera Captures 4K (Pro) or 2.7K (Adv) video & 12.4M Photos
5. DJI Lightbridge Video Downlink, 3.1mi (5Km) range
6. 4S 15.2V 4480mAh Intelligent Flight Battery
7. Four Pairs of Propellers
1. Phantom3 Aircraft
2. Phantom 3 Standard Remote Controller
4. Built-in Camera Captures 2.7 K video & 12MP Photo
5. 2.4G WiFi Video Downlink, 1km range
AIRCRAFT
Diagonal Size (Excluding Propellers) 350 mm 350 mm 350 mm
Weight: (Including Battery And Propellers) 1380 g 1280 g 1216 g
LiPo Battery 4S, 15.2V, 81.3WH 5350mAh Intelligent Flight Battery 4S, 15.2V, 68WH 4480mAh Intelligent Flight Battery 4S, 15.2V, 68WH 4480mAh Intelligent Flight Battery
Charger 100W Flight Battery Charger Remote and Flight Battery Charger
Professional: 100W Charger
Advanced: 57W Charger
57W Flight Battery Charger
Remote is charged via USB
Flight Time 28 mins About 23 mins About 25 mins
Max. Flight Speed 20m/s 16m/s 16m/s
OBSTACLE SENSING SYSTEM
Sensor Optical Sensor N/A N/A
Obstacle Sensor Range 0.7 – 15m (2-49 feet) N/A N/A
POSITIONING MODULE
Outdoors Positioning Module GPS+GLONASS Dual Positioning Module GPS+GLONASS Dual Positioning Module GPS Positioning Module
Vision Positioning Module Vision Positioning System with ultrasonic sensors (Position holding without GPS) Vision Positioning System with ultrasonic sensors (Position holding without GPS) No
Hover Accuracy Vertical: +/- 0.1 m (when Vision Positioning is active) or +/- 0.5 m
Horizontal: +/- 0.3 m(when Vision Positioning is active) or +/-1.5 m
Horizontal: +/- 1.5 m
Vertical: +/- 0.5 m
CAMERA
Sensor 1/2.3″,  Effective pixels  12.4M (Total pixels  12.76M) Sony Exmor R BSI 1/2.3″, Effective pixels 12.4M (Total pixels 12.76M) Panasonic Smart FSI 1/2.3″, Effective pixels 12M (Total pixels 12M)
Video Resolution UHD: 4096×2160 ( 4K ) 24 / 25p
3840×2160 ( 4K ) 24 / 25 / 30p
2704×1520 ( 2.7K ) 24 / 25 / 30p
FHD: 1920×1080 24 / 25 / 30 / 48 / 50 / 60 / 120p
HD: 1280×720 24 / 25 / 30 / 48 / 50 / 60p
UHD: 4096x2160p 24/25, 3840x2160p 24/25/30
FHD: 1920x1080p 24/25/30/48/50/60
HD: 1280x720p 24/25/30/48/50/60
Phantom 3 Advanced
2.7K: 2704x1520p 24/25/30 (29.97)
2.7Kp30(29.997)(2704*1520)
Max. Image Size 4000 x 3000 4000 x 3000 4000 x 3000
Lens FOV 94° 20 mm (35 mm  format equivalent) f/2.8 focus at ∞ FOV 94° 20 mm (35 mm format equivalent) f/2.8
focus at ∞
focus at ∞
Filter Ring Yes, Removable to Allow for ND Filters Yes, Removable to Allow for ND Filters No
REMOTE CONTROLLER & VIDEO DOWNLINK
Dedicated Buttons On Remote Return Home Button Yes Yes No
Video Recording Button Yes Yes No
Shutter Button Yes Yes No
Intelligent Flight Pause Button Yes No No
Flight Mode Switch Yes Yes Yes
Gimbal Dial Yes Yes Yes
2 Dedicated Customizable buttons Yes Yes No
Playback Button No Yes No
Max Transmission Distance CE: 3500 m
FCC: 5000 m (unobstructed and no interference)
CE: 3500 m
CE:500m
FCC:1000m (outdoors and unobstructed)
Video Transmission System Built-in DJI Lightbridge Video Downlink Built-in DJI Lightbridge Video Downlink Built-in DJI WiFi Video Downlink
Video Transmission Distance CE: 3500 m
CE: 3500 m
CE: 500m
FCC: 1000m (outdoors and unobstructed, flight altitude 120m)
Max. Video Bitrate 10M bps Phantom 3 Professional:10Mbps
Phantom 3 Advanced:2Mbps
2Mbps
Max FPV Preview Quality: HD 720P @ 30fps (depending on conditions and mobile device) HD 720P @ 30fps (depending on conditions and mobile device) HD 720P @ 30fps (depending on conditions and mobile device)
One thought on “The Phantom 4 Won’t Disappoint Will It? What Do You Think About DJI’s New Drone?
Leave a Reply
