Hoki
Why does it do this!?  I got a fully charged 5500mah 11.4 volt 3s battery under my s500 frame with a APM 2.8 and 30amp simonk escs.  I have the failsafes off too.  I have two batteries and it does the same thing on both.  Could the battery just be under powered?  I did get cheap 15 dollar floureon battires on gearbest but they are rated at 5500 30c 11.4 volts and I use a Imax b6 charger and it shows that it charges to capacity.  Would it not be supplying the voltage it needs though?  I do have a smaller gauge wire extention cable that goes to the xt60 plug on my frame to the battery.  is that ok or should that 3 inch extension cable by the same gauge as the battery wires for its plug?  Anyways, WHAT'S GOING ON.  Before there was no foam inside the apm case so I put a big foamy foam inside it and it's covering everything and it didn't have any effect.
