For the beginners in drones, we have a panel of expert drone operators ready to answer your questions. You can ask anything, share your projects, ideas, thoughts, etc.
This is a no judgement zone
Throttle stick issues with setting up the Futaba 6K and Naza V2 flight controller. Any thoughts?
I initially had issues using the s-bus channel in that I could not get the "control mode switch" to work on any of the Futaba 6K switches. So I went to the traditional wiring interface. Through the Naza Assistant I can see everything working properly including the control mode switch and IOC. The A,E & R channels are working correctly, however the throttle is reversed (up=slow/down=fast). I have tried reversing the servo both in the Futaba menu and in the Naza Assist and although the stick is traveling in the proper direction, up remains slow. I even went into the Futaba "THR-REV" menu and reversed the switch there, but it's still reversed (up=slow/down=fast). I can start the motors with the stick in the up position and increase speed by pushing to the down position, but can't get it to reverse, or function normally (up=fast / down=slow). Any thoughts on what I might be overlooking?
Did you check off the s-bus spot in the Assistant GUI. first. Be sure the receiver is linked to the TX first in all Futaba Transmitters I have used the Throttle channel always needs to be reversed. I have never used that TX but that is the basics to look at first.Throttle stick issues with setting up the Futaba 6K and Naza V2 flight controller. Any thoughts?
